Connecting Pi robot to router
I was wondering whether it is possible to connect the Pi robot to a router's wifi network and then control it from any device connected to the same network, as opposed to the Pi robot creating its own network.
Also, how easy would it be to add a button to the Pi robot's html control page that can be used to control pins on the Pi or Dagu mini driver? I'm reasonably confident with html, python and arduino scripting, but have never attempted to mesh them all together myself before. The reason for this is, I've mounted a little LED array on the Pi bot's pan/tilt head that acts as a headlight of sorts, however as it's powered by pins on the bot's control boards it is always on by default, it would be nice (although not essential) to be able to switch it on and off at the touch of a button that shifts IO pins from high to low.
