I've built the buggy kit some time ago and for the first few times it was used it seemed to work fine. However now I have a problem with keeping the wifi connected. I have tried a few things to try to eliminate the problem of the wifi ceasing to function after a few minutes. Such as
Tested with multiple wifi dongles including the edimax dongle as suggested
Swapped out the batter pack for a high power RC racing battery pack of the same voltage to eliminate low battery as a cause
Swapped out the Rpi with two other new boards
It came with a pre loaded SD card, I have downloaded and flashed a new 8GB card with the latest image and tested again as above
Tested in various locations to rule out any environmental causes
As of today the buggy will power up, work correctly for maybe a minute or two and then the wifi stops working, if I gently try to move the pan tilt I can feel the servos are working but nothing else is.
I've run out of ideas and things to try so any ideas anyone has will be much appreciated
