Raspberry Pi sleep mode
I have a project that requires an Raspberry Pi to be run from a sealed Lead Acid battery that is recharged from a small Solar Panel.
The RPI periodically turns on a measuring device, via a relay and then monitors the results for a short period of time. The results are then transmitted via a GSM connection. This task only needs to happen four or five times a day, but it is 365 days a year application so the battery needs to be conserved.
I have read that the Arduino draws very little power compared to the RPI. The Co-OP can power the Raspberry Pi, but what I would like to know, is it possible to power it on and off programmatically and if so how?
Christian Rayner
Christian Rayner
