Servo Configuration [Chassis Bundle]
Hi guys
Just a few questions on the servos for the camera pan/tilt kit as part of the chassis bundle, when you get a minute.
1) Is there a way I can change the config to make the servos move faster when I use the web interface thumbstick? When I tap the thumbstick it moves very quickly to the set position, but moving manually is slower.
2) Can the set position when tapping the thumbstick for the camera tilt/pan be set to a different position? I had a play with the 192.168.1.42/config.html file, changing the sliders, but it doesn't seem to save my setting.
3) Is it possible to add my own buttons to the web interface? I'm guessing this is just a matter of messing around with the html side of things, copying existing code? I'd like a few buttons to set the camera in different positions, and also to control some kind of python script to use LEDs connected to the Pi (via a port expander)
Thanks a lot,
Rich
Thanks a lot,
Rich
