¨A https://www.nanodlp.com /forum/viewtopic.php?pid=1807 Z:/Server HD/Library/WebServer/Documents/Web Sites/nanoDLP/www.nanodlp.com/forum/viewtopic63e0.php https://www.nanodlp.com /forum/viewtopic.php?id=296 Z:/Server HD/Library/WebServer/Documents/Web Sites/nanoDLP/www.nanodlp.com/forum/viewtopic63e0.php.z x @]]Z ÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÈ H õ ²~ OK text/html utf-8 gzip (H ²~ ÿÿÿÿ ‹¢™k Tue, 16 Jan 2018 02:02:38 GMT p‘æèµâе⠵â¸læ@µâ >]]Z ÿÿÿÿÿÿÿÿâ ²~
Could I add to the Switch projector On coomand another one to enable
Brilliant Color mode?
Even if set this preset in User 1 mode and save settigs, Brilliantcolor sets to the OFF after reboot.
Enable Brilliant Color 0x06 0x14 0x00 0x04 0x00 0x34 0x12 0x0F 0x01 0x6E
Try [[Projector \x06...]]
Yes, I know that it should be \x06\x14\x00\x04\x00\x34\x12\x0F\x01\x6E
but which field should I add this command?
You should put it inside gcode box you found appropriate. I guess at the end of start/resume boxes (profile) will be ideal place.
Like this? Doesn`t work
This also doesn`t work
No on gcode box you need to add following
[[Projector \x06\x14\x00\x04\x00\x34\x12\x0F\x01\x6E]]
Unfortunately it doesn`t work. Could you suggest the right field for that command?
Update Lamp Hours button in the Projector Calibration menu page doesn`t work also.
\x06\x14\x00\x04\x00\x34\x12\x0F\x01\x6E Brilliantcolor on command
\x07\x14\x00\x05\x00\x34\x00\x00\x15\x01\x63 read lamp usage
I`m still trying to find brilliantcolor mode working (+30% lumens)
Help me please!
Now it works
Error was with 2 spaces instead 1
How could I change command "update lamp time"?
Original button "update lamp time" doesn`t change 0.000000 hours.
How could we solve it?
This is correct command
Try the beta version. There were a bug which thanks to Xmike, it has been solved.
Do I need after upgrading to the beta make factory reset settings?
No you do not need
Beta installed, but still Original button "update lamp time" doesn`t change 0.000000 hours.
Please, paste log output related to lamp hour here.
Unfortunatelly Terminal window clear any information when input these projector Gcode commands.
[[Projector \x07\x14\x00\x05\x00\x34\x00\x00\x15\x01\x63]]
Terminal page could be used to send command to RAMPS and not the projector.
Paste activity log on the dashboard.
Notice 1 2017-01-13 18:32:27.191389 Projector Following string from the projector received
Notice 1 2017-01-13 18:32:26.190633 Projector Start reading lamp hours
Build 1326
Still Lamp Hours shows 0.000000Hours
Viewsonic PJD7820HD
Could you check it again?
I made custom button with same command [[Projector \x07\x14\x00\x05\x00\x34\x00\x00\x15\x01\x63]]
There log with reply:
Debug 1 2017-01-13 18:36:19.467436 Gcode Transfering Data to the Projector [92 120 48 55 92 120 49 52 92 120 48 48 92 120 48 53 92 120 48 48 92 120 51 52 92 120 48 48 92 120 48 48 92 120 49 53 92 120 48 49 92 120 54 51
Put \x07\x14\x00\x05\x00\x34\x00\x00\x15\x01\x63 into Query Lamp Hours field on setup page and try again.
These command from manual:
Lamp Time
Write Reset Lamp
usuage hour 0x06 0x14 0x00 0x04 0x00 0x34 0x15 0x01 0x00 0x62
Read Lamp usuage
hour 0x07 0x14 0x00 0x05 0x00 0x34 0x00 0x00 0x15 0x01 0x63
This command \x07\x14\x00\x05\x00\x34\x00\x00\x15\x01\x63 already in place more than 2 weeks but does not work
UNKNOWN 2017-01-13 20:52:28.594294 {"Layer":"50","module":"Projector","level":"Notice","msg":"Following string from the projector received "}
Notice 50 2017-01-13 20:52:27.593451 Projector Start reading lamp hours
Have you tried turn on/off the projector through nanodlp?
Yes, commands on/off and brilliant color work fine.
Lamp Time
Write Reset Lamp
Read Lamp usuage
hour 0x07 0x14 0x00 0x05 0x00 0x34 0x00 0x00 0x15 0x01 0x63This command \x07\x14\x00\x05\x00\x34\x00\x00\x15\x01\x63 already in place more than 2 weeks but does not work
"Unknown" it was command switching projector menu to English language.
The command is correct. Am I right?
No it means you have filled the correct input box and it try reading the value.
