�Ahttps://www.nanodlp.com/forum/viewtopic.php?pid=757Z:/Server HD/Library/WebServer/Documents/Web Sites/nanoDLP/www.nanodlp.com/forum/viewtopic8ba7.phphttps://www.nanodlp.com/forum/viewtopic.php?pid=782Z:/Server HD/Library/WebServer/Documents/Web Sites/nanoDLP/www.nanodlp.com/forum/viewtopic8ba7.php.zx;\]Z������������������������F~OKtext/htmlutf-8gzip (HF~�������kTue, 16 Jan 2018 01:58:17 GMTp��������l�@��9\]Z��������VF~ final stage (Page 2) / Help and Support / NanoDLP Forum
#26 2016-05-02 19:38:12
mandreas
Re: final stage
#27 2016-05-03 17:20:48
mandreas
Re: final stage
#28 2016-05-10 20:53:56
mandreas
Re: final stage
Hi Shahin,
I'm so happy to show you the first print made with my top down, it is a holder  for the servo motor, the resin is not the best and the Z resolution is  only 100 microns, but the result is  fantastic,
thanks Shahin, for your support, thank Nano dlp
#29 2016-05-10 21:02:31
Re: final stage
Nice print and build platform
#30 2016-05-15 08:37:31
mandreas
#31 2016-05-19 21:28:19
mandreas
Re: final stage
hello Shahin,
until now I used nanodlp with satisfaction, but today, when I finish slicing and I start printing, the system crashes,
attach the debug files, can you figure out why?
Thank you
https://drive.google.com/file/d/0B4QD7f … sp=sharing
#32 2016-05-20 06:57:30
Re: final stage
Hi Andrea,
It looks like RPi itself has been crashed. It could be power problem or something similar which has not put any trace behind.
#33 2016-05-21 15:02:04
mandreas
Re: final stage
Thanks Shahin,
I solved the problem by removing all profiles plate, and recreating them again, probably by importing them from the previous version, created some conflict,
Cheers ,Andrea
#34 2016-05-31 19:31:05
mandreas
Re: final stage
good result 30 microns, a few holes on the surface due to the imperfect model 3d, Rpb crashed 2 times, but I hope with the new PCB to solve...
#35 2016-06-11 19:19:37
yonray
Re: final stage
Hi mandreas,
Excellent work, wonderful prints!
#36 2016-06-11 19:22:20
mandreas
Re: final stage
I can say now, that I've solved all the problems, and my "top down" works like a champ,
I added the shutter, and  no more reported crash, in short, im  happy, thank especially to the precious help of Shahin and his creating Nanodlp !!!
#37 2016-06-11 19:27:00
yonray
Re: final stage
That looks great!
#38 2016-06-12 10:29:00
mandreas
Re: final stage
This short shutter  video (made with smartphone)...
https://youtu.be/5gPIZ_rOtoc
#39 2016-06-12 17:02:09
Re: final stage
What are the use of the second box with built-in matrix lcd?
#40 2016-06-12 18:18:28
mandreas
Re: final stage
it is a power supply, step down, adjustable volts (24 to 5) that provides 5 amperes, powers the rpb and the servo motor
#41 2016-06-14 19:45:27
mandreas
Re: final stage
last test print:
#42 2016-06-15 13:44:25
jimshealy
Re: final stage
If you don't mind me asking, what are your settings?
#43 2016-06-15 15:37:40
mandreas
Re: final stage
Then, I used a "magic potion" a mix of advanced resins, 60 microns z, xy 67, exposure time 6 seconds
#44 2016-06-22 17:05:15
mandreas
Re: final stage
Hi Shahin,
I changed the micro SDHC card class 10 hc 1, but sometimes still happen blocks, attach the debug files, could you please help me? thank you
https://www.dropbox.com/s/sjqqyq5653n5f … 7.zip?dl=0
#45 2016-06-22 17:39:36
Re: final stage
Hi Andrea,
It looks like rpi crash. Is the same source power stepper driver and rpi?
We had experienced same kind of behaviour with shared power supply, rpi is very sensitive in this regard
#46 2016-06-26 08:57:15
mandreas
Re: final stage
Shahin wrote:
Hi Andrea,
hi Shahin,
I tried with a specific power supply for raspberry, 2A , but the problem happens the same, I came back with step-down power supply, but I used a good quality cable 10cm long, the efficiency has improved a lot, no more crash a part  one time , during the stepper movement that returned high in the post-exposure movement, I noticed on  lCD, the amperage was stuck at 700 mA, as if , this movement, absorb much current from rpb...
#47 2016-06-26 09:51:13
yonray
Re: final stage
How much voltage are you supplying to your setup? I read some where that if a supply of 5.25V is applied it will be enough to account for the voltage drop based on the high loads.
#48 2016-06-26 10:31:33
mandreas
Re: final stage
thanks very much yonray, I adjusted the voltage to 5.1 v, I do not want to overdo it and fry the RSB, it seems to run very well
#49 2016-06-26 12:26:16
yonray
Re: final stage
You're welcome! I am glad I could help.
#50 2016-07-11 20:57:49
mandreas
Re: final stage
Never trashing old motherboards;) laminated plate copper on the RBI, noting the temperature, with the processor to 75%
