Alan wrote:Hi Phil,
Are the batteries you're using rechargeable, or non-rechargeable? Non-rechargeable will struggle to provide the current needed to the Pi, motos and WiFi all at once.
I would say that for reliability, you should use rechargeable batteries if possible. I have had the robot run off non-rechargeable batteries but runtime is very low (only 30 minutes approx) success depends on
- Batteries used - Duracell are a good brand, so should be ok
- Type of Pi - The new model B+ draws less current
- Type of WiFi adapter - the recommended Edimax EW-7811Un seems to draw less current than other WiFi dongles.
If you are using rechargeable batteries then I need to have a bit more of a think. If they're rechargeable, what is their capacity in terms of mAh?
Alan wrote:Hi Phil,
In that case I think the best thing to do is to try rechargeables (Duracell 2400mAh are good). In our blog post on battery life we were able to run a robot with a Model B Pi on alkaline batteries (Sainsbury’s Extra Long Life) for approx 50 minutes), but it was rubbish compared to NiMh batteries.
Out of interest, do you have the updated version of the kit containing a UBEC? (this should be included if you bought your kit after August).
