I am new to the robot world, however got plenty of experience with computer & linux.
With the recent purchase of your robot kit, I am really struggle to get the mini driver working. By looking the forum, it feels like the common issue other people has.
I am using the SD card image download from website, however I cannot make the robot move. By ssh to the rpi. I found it refused to connect to the mini driver. The following the message when try robot_sensor_test.py (I enabled debug info)
- Code: Select all
avrdude: Version 5.11.1, compiled on May 23 2012 at 11:08:25
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/etc/avrdude.conf"
User configuration file is "/home/pi/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : arduino
Overriding Baud Rate : 19200
AVR Part : ATMEGA8
Chip Erase delay : 10000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 4 20 128 0 no 512 4 0 9000 9000 0xff 0xff
flash 33 10 64 0 yes 8192 64 128 4500 4500 0xff 0x00
lfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
lock 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
calibration 0 0 0 0 no 4 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9307
avrdude: safemode read 1, lfuse value: 0
avrdude: safemode read 2, lfuse value: 0
avrdude: safemode read 3, lfuse value: 0
avrdude: safemode: lfuse reads as 0
avrdude: safemode read 1, hfuse value: 0
avrdude: safemode read 2, hfuse value: 0
avrdude: safemode read 3, hfuse value: 0
avrdude: safemode: hfuse reads as 0
avrdude: reading input file "/home/pi/.ino_uploader/mini_driver_firmware/.build/atmega8/firmware.hex"
avrdude: writing flash (6858 bytes):
Writing | ### | 5% 0.22savrdude: ser_recv(): programmer is not responding
avrdude: stk500_recv(): programmer is not responding
DEBUG:root:uploadResult = 1
connected = False
lsusb -v
- Code: Select all
pi@raspberrypi ~/raspberry_pi_camera_bot $ lsusb
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 0951:1665 Kingston Technology
Bus 001 Device 005: ID 0b05:1786 ASUSTek Computer, Inc. USB-N10 802.11n Network Adapter [Realtek RTL8188SU]
Bus 001 Device 011: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light
I also tried Arduino IDE on desktop with CP210x UART driver, I got the same error
- Code: Select all
Can you please help?
Many thanks
Jesse
