Hi, thank you very much for your awesome product! Finally I've got through all obstacles and successfully built this awesome robot, but I have big problem: Wi-Fi connection is sluggish, robots reaction is delayed about 10s, as well as refreshing webcam stream. I'm getting 1 FPS per 5-10sec, sometimes it disconnect, etc..
Robot is uncontrollable this way.. But when I try e.g. change default values of servos (on /config.html page), it reacts immediately.
I'm adding log from /log.html:
DEBUG:tornado.general:sockjs.tornado will use json module
INFO:root:Starting web server...
WARNING:root:Got message with invalid checksum
INFO:root:Read 0XACED 0.38
INFO:root:Expected 0XACED 0.38
INFO:tornado.access:200 GET / (192.168.42.14) 67.12ms
INFO:tornado.access:304 GET /css/style.css (192.168.42.14) 86.91ms
INFO:tornado.access:304 GET /css/modal.css (192.168.42.14) 11.75ms
INFO:tornado.access:304 GET /js/jquery.js (192.168.42.14) 33.20ms
INFO:tornado.access:304 GET /js/jquery.joystick.js (192.168.42.14) 11.87ms
INFO:tornado.access:304 GET /js/sockjs-0.3.min.js (192.168.42.14) 13.94ms
INFO:tornado.access:304 GET /images/ajax-loader.gif (192.168.42.14) 15.10ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.14) 8.50ms
INFO:tornado.access:200 GET /logs.html (192.168.42.14) 16.28ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.14) 8.35ms
INFO:root:SockJS connection closed
INFO:tornado.access:304 GET /config.html (192.168.42.14) 11.26ms
INFO:tornado.access:304 GET /css/config.css (192.168.42.14) 28.62ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.14) 6.91ms
INFO:tornado.access:200 GET / (192.168.42.14) 9.79ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.14) 5.72ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.14) 7.42ms
INFO:tornado.access:304 GET / (192.168.42.14) 9.18ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.14) 7.02ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.14) 6.75ms
INFO:tornado.access:304 GET /logs.html (192.168.42.14) 13.20ms
INFO:tornado.access:304 GET /js/jquery.js (192.168.42.14) 8.60ms
INFO:tornado.access:304 GET /js/sockjs-0.3.min.js (192.168.42.14) 10.74ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.14) 6.99ms
Can you please help me? Thank you!!
