Hi, I'm looking to build a robot using a Rpi and an Arduino. The Co-op looks like a good way to do that, but I'm a little confused about power. Most Arduinos seem to have a linear step-down voltage regulator to take the battery voltage down from typically 7.2 to 5, but the co-op runs from 5, correct?
The manual talks about running the Rpi from a voltage regulator attached to the Co-op, but the diagram looks like the Co-op is powered from the Rpi. Do I just plug the Co-op on to the Rpi & that's it? It that's so I just need an external 5v regulator (again assuming a 7.2v battery supply) for the Rpi?
One more thing if I may, there does not seem to be a physical fitting to the Co-op, just the plug, have you experienced any problems with vibration in a robot environment?
thanks, pete.
