This is working, not an issue with getting it to work as such, but despite me leaving the current speed in effect for 5 seconds (i.e., I'm not sending a new signal to change speeds within that 5 seconds), the wheels only appear to run for 2 seconds and then stop.
I tested this theory by having the script set the wheels to a value of 20 (fairly sedate), waiting 5 seconds, then setting them to 80 (belting along), waiting another 5 seconds, and then finally setting them back to 0.
What I'm actually getting is 2 seconds of slow rotate, back to still for the remaining 3 seconds, then 2 seconds of fast rotate, back to still for the remaining 3 seconds. I can confirm the timing is working as I do get the 5 seconds before it changes speed (and then prints the final message).
I can't see anything in the mini_driver.py file which might suggest a time limit... and indeed, if you keep your foot on the joystick on the web page it will go for longer than 2 seconds.
Note that I *am* running this test with the wheels running free, as my Pi is using the mains power so I don't want it unplugging itself by running away across the floor
Any ideas? Am I supposed to keep re-enforcing the outputs at regular intervals? This seems a little tedious.
