Dagu Mini Driver Issue
Re: Dagu Mini Driver Issue
Postby Alan » Wed Oct 07, 2015 5:52 pm
Sorry for the delayed reply on this. I can't think of a good reason why this wouldn't work but have a list of things to try. If it doesn't work after this then we'll replace the hardware
  • If you attach the motors to the battery directly, do they turn?
  • Do you have any kind of bench top power supply that you could use to power the mini driver instead of the batteries to see if that helps?
  • Does the blink sketch work on the mini driver?
Apologies that you're seeing this problem.
Postby 3dsource » Wed Oct 07, 2015 7:18 pm
Thanks for the reply. I tried the hooking the battery directly to the motor and it runs very fast.
I don't have a variable power supply but I have a couple of wall adapters ranging from 5 to 16 volts with various amp levels. Whats the max/min supply voltage of the board?
The blink sketch works and the blue light happily blinks.
I'm sorry for the trouble I am trying everything I can think of.
3dsource
Previous
Users browsing this forum: Yahoo [Bot] and 0 guests
