I assembled my Raspberry Pi Camera robot but it does not work properly. Sometimes if I start the robot it is partially working (pan/tilt works always, camera does not work right now but can be something else, one of the motors are working). If I start the robot the next time nothing works and this is the log. It seems to me that the firmware was not installed correctly on the first start and now it sometimes tries to install the firmeware again but that does not work properly. Does anyone please have a suggestion? Is there a way to just reset the firmware manually?
Best,
Dirk
DEBUG:tornado.general:sockjs.tornado will use json module
INFO:root:Starting web server...
INFO:root:Read 0X0 0.0
INFO:root:Expected 0XACED 0.38
INFO:root:Unable to connect to correct firmware, uploading...
INFO:root:No file copy needed
DEBUG:root:Building sketch in dir /root/.ino_uploader/mini_driver_firmware
DEBUG:root:Trying to upload /root/.ino_uploader/mini_driver_firmware/.build/atmega8/firmware.hex
DEBUG:root:uploadResult = 0
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 6.52ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.57ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.62ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.03ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 2.34ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 2.40ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.47ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.37ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.46ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.38ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.56ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.33ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.30ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.54ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.16) 3.49ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.97ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.41ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.40ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.34ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.49ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.87ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.32ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.45ms
INFO:tornado.access:200 GET / (192.168.42.16) 52.23ms
INFO:tornado.access:200 GET /css/modal.css (192.168.42.16) 34.23ms
INFO:tornado.access:200 GET /css/style.css (192.168.42.16) 5.75ms
INFO:tornado.access:200 GET /js/jquery.joystick.js (192.168.42.16) 8.21ms
INFO:tornado.access:200 GET /images/ajax-loader.gif (192.168.42.16) 8.04ms
INFO:tornado.access:200 GET /js/sockjs-0.3.min.js (192.168.42.16) 31.07ms
INFO:tornado.access:200 GET /js/jquery.js (192.168.42.16) 102.14ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.16) 2.52ms
WARNING:tornado.access:404 GET /favicon.ico (192.168.42.16) 18.23ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 2.45ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 2.49ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.72ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.26ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.27ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.39ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.74ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.15) 3.50ms
INFO:tornado.access:200 GET /logs.html (192.168.42.16) 7.78ms
INFO:root:SockJS connection closed
INFO:tornado.access:304 GET /js/sockjs-0.3.min.js (192.168.42.16) 4.35ms
INFO:tornado.access:304 GET /js/jquery.js (192.168.42.16) 4.00ms
INFO:tornado.access:200 GET /robot_control/info (192.168.42.16) 3.40ms
