#1 2018-02-01 13:06:11
xiao1235
Banned
carved structure
<p>speaking, single lock buckle or double lock buckle is enough, again more is completely unnecessary. For tension resistance, straight and oblique wood floor, its better. It seems that the choice of wood flooring is a door of learning, consumers should carefully distinguish clearly, must not be credulous manufacturers exaggeration propaganda. PY9174 Evaluation of Seven Trust Antique Wood plastic flooring </p>
<p>Seven trust antique seven trust wood plastic flooring PY9174 appearance mild, simple and generous, relatively easy to collocation furniture, this section of the floor innovation has several points, first, the floor material layer from the traditional 8mm to 11mm. Comfort and service life are relatively improved, and the bottom floor of the added light sound pad, people walking above, sound more pure, but also </p>
<p>increased its elasticity, as well as its unique 4-corner V-groove. It looks very three-dimensional. We all know that wood and plastic flooring is wear-resistant, anti-fouling, waterproof, and today we also proved the excellent performance of the seven real flooring with a fresh test. The color of this section of the floor is relatively light, so it is easier to match furniture, and the light color can make the small room </p>
<p>no paint home siding<br />
dark gray solid wpc deck antiuv waterproof wpc wood  swimming pool  decking  composite  decking<br />
good price wpc wood plastic composite flooring decking  with sgs</p>
