#1 2018-03-02 08:01:30
xiao1235
Banned
single-board and double-board big board
<p>board. GRC wall hanging board is divided into two kinds of window panels and window boards, thickness 10mm, rib height 70mm, weight 50 ~ 60kg / O. GRC rock wool wall siding installation order is to rock wool board fixed to the brick wall with nails, with 22 galvanized iron wire into a mesh so that the rock wool board close to the brick wall, and then from up to install the window panel And the window </p>
<p>board. Conclusion: The above is introduced GRC composite wall panels classified knowledge Daquan, I hope for your help. Learn more building materials knowledge, welcome to continue to pay attention to every home decoration Raiders.</p>
<p>composite and plastic decking wholesale<br />
anti corrosive composite decking price<br />
plastic swimming pool walls</p>
