<p>The method of maintaining composite wood floors is simple. You can usually use a vacuum cleaner or a broom to clean the surface of the dust, and then use a cloth or mop that has been soaked and wrung out until it how do i add handrailing to my steps does not drip. After the floor is mopped, it is best to open doors and windows to allow the air to circulate and dry the floor as quickly as possible. If the composite wood floor wear layer is damaged, it will affect the moisture-proof function and brightness of the floor. Therefore, when walking on the floor, it is best to wear cloth slippers, preferably barefoot. </p> <p>A soft-bottomed protective pad is attached to the pvc cladding board suppliers new zealand furniture feet to prevent the furniture from scratching the floor wear layer, so that heavy items do not damage the wear layer. Do not use sandpaper, sanders, steel brushes, strong detergents or metal tools to clean laminate flooring.</p> <p> If you have a cat in your home, you need to find a solution to the destruction of cat claws. Here's a tip for cleaning a light-colored composite wood floor: Use a rag to scoop upCheap Upvc Front Door Panels the tap water and wipe it directly on the floor, or spray the rice water evenly on the wooden floor (not too much) and wipe it with a dry rag for 5 minutes. The floor will be much cleaner.</p> <p> Special stains cleaning: Oil stains, paints, and inks can be wiped with a special stain-removing oil; stains such as blood stains, juices, red wine, and beer should be wiped with a damp cloth or a suitable amount of floor cleaner with a rag; wax and chewing gum with ice cubes Put it on for a while, freeze it to shrink it, then scrape it gently, then wipe it with a damp cloth or with a rag and a suitable korean outdoor deck amount of floor cleaner. Can't use powerful acid and alkali liquid to clean composite wood floor.</p>
