<p>How to find out the problem wall four little dice Causes of coating cracking and shedding: The coating showed cracks like hair filaments in the early stages and exfoliated later in the process. Most of the best price for aeratis porch flooring paints used were poor adhesion and flexibility, over-dilution, or coating materials, or walls. The surface of the base layer is not sufficiently pretreated, and the film hardens and embrittles after aging. Recommendation: Remove loose and peeling paint with a spatula or wire brush, sand the surface and trim. </p> <p>If spalling occurs on multiple coats, water-resistant putty should be used where to buy composite gate slats if necessary. The primer must be closed before recoating. The use of good quality primers and topcoats can prevent the recurrence of such problems. Do not over-dilute the paint with water. Causes of mildew: Causes black, gray, or brown spots on the surface of paint or wall surfaces where moisture, light is not visible or in direct sunlight (such as bathrooms, kitchens, laundry rooms, etc.).</p> <p> Before the use of inferior emulsion paint or coating, the substrate or the coating on the coating was not cleaned. Recommendation: Place a few drops of household bleach in the area of deck board 48 m discoloration to detect the presence of mold. If the stain disappears, it may indicate mold. Wipe the surface with a diluted household bleach solution (one part bleach to three parts water) to completely remove the mold. Rinse thoroughly with rubber gloves and goggles while working. To avoid mildew on the walls, use a regular manufacturer's high-quality latex paint. If necessary, use a bleach/detergent solution to clean wood wall construction the substrate and consider installing an exhaust fan in a high-humidity area.</p>
