#1 2018-03-19 16:36:26
xiao1235
Banned
Polyurethane is a flame retardant
<p>board has good thermal insulation properties, the thermal conductivity of about 0.023W / (m  k), far below the market commonly used inorganic, organic exterior insulation products can reach more High energy-saving effect. Third, light weight, non-absorbent phenolic insulation board light weight, bulk density is generally 30-80Kg / m3. At the same time phenolic insulation board is not absorbent, not afraid of rain. Fourth, </p>
<p>the safety and environmental protection Phenolic insulation board is environmentally friendly green products, will not irritate the skin, will not cause any harm to the human body, burning non-toxic smoke release (limited conditions, the limit of over the release of formaldehyde, carbon monoxide, etc.). Fifth, good dimensional stability Phenolic insulation board has a very good dimensional stability, no matter under what </p>
<p>circumstances, will not shrink, deformation and so on. Sixth, the use of phenolic insulation board not only can be used for building exterior insulation systems, can also be used in movable room, purification plant, cold storage Caigang sandwich panels, air duct, pipe insulation, curtain wall insulation, roof insulation, room Cabinet insulation, equipment insulation, carbon crystal electric plate insulation and various needs of </p>
<p>wpc decking composite fence panels estimate<br />
2x6 tongue and groove treated lumber carters<br />
wpc decking for outside from spain</p>
