<p>Electro-foiling is a kind of hot stamping material which is made by coating and vacuum-depositing a layer of metal foil on the film base. The thickness of aluminum is generally. Aluminum foil is coated on the Wooden Decking Prices Uk film from the layer, color layer, the vacuum coating of aluminum and then coated layer, and finally through the finished rewinding made. Domestic aluminum foil is generally 4 to 5 layers. How to choose the selection of aluminum foil must pay attention to match with the hot stamping substrate. </p> <p>What kind of substrate to choose the type and type of aluminum is not the same. For example: Music Technology HB HB-type aluminum is used in cloth, and you are to stamp on the plastic, it certainly can not match. Another example: Music and Technology GS series is used in glass Composite Decks Costs Calculator Costa Rica bottles on your paper, it is not enough. Therefore, the user in the choice of aluminum, in addition to considering the color and price of aluminum, the substrate stamping and the surface state (whether in the printing ink layer, the surface of the coating or coating hot stamping) is necessary to supply Business explanation.</p> <p> Applications General plastic gold foil paper: for the diversity of plastics, can provide hot foil in a variety of materials on the foil. Paper gold foil paper: can be provided in a variety of hot paper and foil on a variety of bronzing composite floor slabs foil (gold, silver, red, blue, green, black and white), laser foil, colorful foil, colorful foil, widely used in smoke Boxes, wine boxes, greeting cards, calendars, lottery tickets (scraping music) and other paper products. </p> <p>Cloth-type gold foil paper: for the special needs of fabrics such as washable, professional to provide Germany, Taiwan and other imported fabrics printed bronzing foil, fastness, brightness up to international standards test. Auxiliary materials bronzing: A bronzing version, bronzing wheel, foil cutting machine and other auxiliary materials sales bronzing, bronzing version, bronzing wheel do theme park sell decking stain is divided into two kinds of Japan and Taiwan, the mill durable.</p>
