<p>the wallboard model, GRC composite wallboard can be divided into two types of single-board and double-board big board; according to the classification of insulation materials, cement perlite composite wall panels, rock wool board composite panels or polystyrene Vinyl foam composite wall panels and so on. GRC composite wall panels size specifications, light weight, surface modeling is rich, easy </p>
<p>construction, it is particularly suitable for frame structures, especially in the high-rise frame building as a non-load-bearing wall siding use. Second, GRC exterior insulation board GRC exterior insulation board, also known as fiberglass cement polybenzene composite insulation board, is based on GRC for the surface, polystyrene foam board for the core to the pedestal method or group of legislation </p>
<p>Production of sandwich-type composite insulation board. Such boards of light weight, waterproof, fire performance, and has high resistance to bending, impact resistance and good thermal performance. Production of glass fiber reinforced cement polystyrene insulation board generally require the intensity level of 52.5 fast hardening sulphoaluminate cement, reinforced materials using alkali-resistant glass fiber </p>
<p>composite landscape timbers<br />
composite wood furniture in pennsylvania<br />
structural plywood board</p>
