#1 2018-01-31 09:13:53
xiao1235
Banned
architectural pottery domestic
average specific power consumption obtains the main product such as cement, glass, architectural pottery domestic advanced level, proportion of product of green building materials rises what is a good deck warranty steadily, cement kiln deals with in coordination product line is occupied than 15% above, the main contaminant such as compound of oxygen of sulfur of dust, 2 oxidation, nitrogen is discharged achieve country, province relevant specification
requirement. In respect of new-style wall pressure treated split rail fence material, linyi city will emphasize face to develop to pledge gently, excel in, fast, taste direction of product of material of the body that change a wall to send force from sex of heat preservation, function, ministry. Use the rate of manufacturing headroom hole such as industrial waste residue, excel in to be mixed from the hollow block of heat preservation cost to redo a wook deck direction wait for
agglomeration from heat preservation block kind product; uses building litter to produce the building block, brick that show water and adiabatic thermal insulation compound how to build a house using composite panels unifinication assembles type, popularize vacuum the insulation material of the intrinsic safety such as heat insulation board, energy-saving, green. Additional, to get used to a building industrial modernization needs, around assemble type concrete
