#1 2018-01-12 23:39:41
xiao1235
Banned
built-in heat medium, with independent heating energy
<p>heating and passive thermal conductivity; the following we understand the floor heating Composition of materials and production processes. 1, carbon fiber Carbon fiber is a microcrystalline graphite material obtained by carbonization and graphitization of organic fibers. The microstructure of carbon fiber is similar to artificial graphite, which is a turbulent graphite structure. Carbon fiber is an inorganic polymer </p>
<p>fiber containing more than 90% carbon. Carbon content of more than 99% of which is called graphite fiber. Carbon fiber axial strength and modulus of high, low density, high performance, non-creep, non-oxidizing environment resistant to high temperature, fatigue resistance, specific heat and conductivity range between non-metallic and metal, the thermal expansion coefficient Small and anisotropic, good </p>
<p>corrosion resistance, good X-ray permeability. 2, Carbon fiber fusion technology mainly refers to the integration of carbon fiber with a variety of materials, add the use of technology, in view of the physical characteristics of carbon fiber, carbon fiber can be processed into fabrics, felts, mat, belt, paper and other materials. In addition to the traditional use of carbon fiber insulation materials used in addition to </p>
<p>layer wood panels outdoor<br />
High Density furniture pvc celuka board<br />
wood plastic composite rapidly</p>
