#1 2018-01-30 23:26:08
xiao1235
Banned
partition board knowledge, please continue
<p>to expand the housing space Light partition wall is divided into interior walls and exterior walls, partition wall panels can fully expand the space of the house. 4, the overall good Because it is assembly-type construction, the body of three-in-one structure, board and board connected into a whole, strong impact resistance, anchoring with steel structure, the wall strength, can be made of high, Body, the overall </p>
<p>seismic performance is several times higher than ordinary masonry walls. Composite wall partition system has the advantages of compact structure, good integrity, no deformation, not easy to loose wall and good earthquake resistance. 5, moisture proof waterproof proof, lightweight wall panels in the absence of any waterproof finish, cement bonded into a pool filled with water, light back of the wall to keep dry, </p>
<p>leaving no trace in wet weather There will be no condensation in the water droplets. Lightweight wall panels panel is a professional waterproof board, a good waterproof, moisture-proof performance, suitable for kitchen, bathroom, basement and other wet areas. 6, sound insulation has a good sound insulation effect, the sound insulation effect in line with national residential sound insulation requirements, </p>
<p>can composite decking lay on ground<br />
outside deck railing designs<br />
where should solid hardwood be installed</p>
