#1 2018-01-19 11:42:24
xiao1235
Banned
other global problems; the other hand
<p>types, PVC plastic floor, marble floor, ceramic tile, floor mats, etc. Below we take a look at these advantages and disadvantages of the elevator floor. 1, PVC plastic flooring PVC plastic flooring refers to the use of polyvinyl chloride material production Jiate flooring. It is a light body floor decoration materials, play energy saving, environmental protection, durability, beauty. 2, marble floor </p>
<p>marble floor is made of clay firing, a variety of specifications. Quality strong, small capacity, pressure resistant, moisture-proof. Some glazed, decorative, and more for public buildings and civil buildings on the ground and floor. Marble floor is not deformed, high hardness, abrasion resistance. Anti-abrasion, high temperature, maintenance-free. Physical stability, well-organized by the impact </p>
<p>of grain fall off, the surface is not rough edges, does not affect the plane accuracy, material stability, to ensure long-term deformation, linear expansion coefficient is small, but the marble floor radiation is also a well-known problem. 3, ceramic tile is a refractory metal oxide and semi-metal oxide, through the grinding, mixing, pressing, glazing, sintering process, and the formation of a kind of acid or </p>
<p>roof terrace tiles texture<br />
portable composite deck flooring<br />
pontoon boats plastic benches</p>
