#1 2018-04-05 17:15:27
xiao1235
Banned
formaldehyde emissions
<p>expansion and contraction, although it will not cause a fire, but the product will be deformed, aesthetics will be greatly reduced, the appearance of the color may also change. Mianqi maintenance mistakes Three free paint plates do not need to be cleaned. Dust prevention is an advantage of the wood, but this does not mean that you should not clean it as it is likely to cause stubborn stains due to long-term </p>
<p>uncleanness, which is detrimental to the long-term use of the product. Paint-free maintenance of the three major errors, everybody Xiaobian temporarily to share here, I hope your home maintenance help, for more knowledge of paint-free maintenance, please continue to pay attention to every home decoration network.Paint-free board, also called melamine board, is to put paper with different color or texture into </p>
<p>the melamine resin adhesive and then dry it to a certain degree of curing, and apply it to particleboard, moisture-proof board, medium density fiberboard, plywood, fine Wood board or other solid wood above the board, the pressure from the decorative plate. Let us take a look at the advantages of free paint board, use and environmental performance. One, no paint board advantages Paint-free decorative </p>
<p>replaceing boards on yard bench<br />
bathroom panel for sale in UK<br />
wood polymer composites</p>
