#1 2018-03-23 10:18:14
xiao1235
Banned
PVC and Composite Decks
<p>cedar deck longevity<br />
laying a diagonal deck<br />
wood soffits for home</p>
What is so unique about Endeck decking?
Endeck deck boards are made with proprietary compounds that give them a more uniform cell structure inside eliminating the voids commonly seen in competitive deck boards. Endeck boards are strong, durable, engineered to resist sagging, and lighter in weight (only 1.55 lbs. per ft.) than composite, capped composite or most treated wood deck boards. The dual embossed woodgrain on both sides of Endecks cellular PVC deck boards mimic the look and feel of real wood. Endeck decking is available in 12, 16 and 20 lengths, in 8 colors, with fascia to match or contrast for a flawless finish.
Endeck Forest Series employs our exclusive HardCover? Capstock, a higher performance outer surface delivering unmatched durability and ultra-low maintenance.
marina decking boat dock deck planks
Forest? Series is definitely a strong visual statement with a deeply embossed wood-grain and rich, dark colors with subtle variegation only found on the most expensive, exotic hardwoods. Just like real wood, our decking has a natural grain and texture that varies from board to board for a truly authentic finished deck. Additionally, these deep beautiful colors also offer an impressive 30 Year Fade and Stain warranty with QUV testing showing a consistent fading less than 5 Delta E. Forest colors are available in Slate, Chestnut, Sequoia, Cedar, and Sable (special order
