#1 2015-12-08 15:10:38
rocha
Source model files?
Which ones are the source files for Plen's body? The ones from Blender or the ones from Solid works?
In other words, if I want to edit a body part, what files should I use as a start?
#2 2015-12-12 03:03:58
Guvalif
Moderator
Re: Source model files?
Hi, rocha
We have been applying the development process that using Blender for the high design quality parts and using SolidWorks for mechanism elements, so you should use both 3DCAD.
In the future, all parts will be implemented by SolidWorks.
#3 2015-12-14 17:34:04
rocha
Thanks Guvalif!
What about using software that is more accessible to hobbyists? Solidworks is very expensive!!!
Some alternatives: Autodesk Fusion 360 (free for hobbyists), OnShape (public designs are free).
#4 2015-12-15 07:56:57
PLEN Project Committee
Hi rocha,
You can use solid works files by Autodesk Fusion 360.
FYI:
https://plen.jp/playground/forum/viewtopic.php?id=2
#5 2015-12-15 13:08:06
rocha
Perfect! Thanks.
