#1 2015-10-16 19:00:18
Tueddy
testing firmware on blank Arduino Micro
Hello Plen2 team,
first to say: Plen2 is the most beautiful mini robot i've seen, my son will love him. Domo arigato, Mr. Roboto!
I've uploaded the firmware to a naked Arduino Micro to make some tests.
Firmware is well structured using classes, separate units and easy to understand namespaces.
Well done!
1.) Plen2 doesn't say: "Hello my name is Plen2, my system is up and running firmware 1.xx, let me walk!" This would be very helpful to test
2.) <vi command does nothing?
3.) Enabling DEBUG: "xxx in fuction" should it be "xxx running in funCtion"?
4.) It's unclear how USB-/BLE serial work together. When i connect a BLE serial shield i can communicate via both connections?
Thanks so far
Best regards
Dirk
#2 2015-10-17 13:00:57
Guvalif
Moderator
Re: testing firmware on blank Arduino Micro
Hi, Tueddy.
Thank you for your cheering! We work for people get more fun through PLEN, always have, always will :)
1.) OK, I'll think about this.
2.) No, "<VI" command has implemented since firmware version 1.1.0. For example, I have installed firmware version 1.2.1 to my PLEN2, and then send the command, I can get json like below.
```json
    "device": "PLEN2",
    "codename": "Cytisus",
    "version": "1.2.1"
I thought that you are not using PLEN2's baud-rate. PLEN2 and other component to communicate with baud-rate of 2,000,000.
(It's defined here: https://github.com/plenproject/plen__fi … .h#L37-L41)
3.) Oh... I had not noticed the typo X(  This bug has fixed currently, please check below.
https://github.com/plenproject/plen__fi … 386213f120
4.) That's right you intended.
#3 2015-10-17 21:01:12
Tueddy
Thanks Guvalif for explaination!
Typo is fixed, perfect!
My baudrate seems to be wrong, but in Arduino IDE i cannot set to 2,000,000? Max value in serial monitor is 250,000 baud.
Is there a line like Serial.begin(9600);? I did not found it..
Dirk
#4 2015-10-17 23:40:11
Guvalif
Moderator
> ... but in Arduino IDE i cannot set to 2,000,000?
Yes, we use other terminal emulator to communicate with PLEN2. (In japan, the most popular one is Tera Term.)
If you want to use other baud-rate, please change their definition that described before, or write "Serial.begin(xxx);" directly in the setup().
(By the way, the firmware calls Serial.begin() at here.)
If you are interested, let get the additional information why we are using baud-rate 2,000,000.
(Reference: http://wormfood.net/avrbaudcalc.php?pos … detables=1)
#5 2015-10-20 10:53:13
Tueddy
Hi Guvalif,
thanks now i see! <vi works and i can upload motion with latest motion installer for win.
I'll try a bluetooth HM-11 BLE 4.0 module because BLE113 visual is not available in germany.
The HM-11 is cheap and seems to work with iOS. I'll report back here if it works.
Best regards
Dirk
