i want to be able to adjust my 0 postition manualy an then tell nano dlp to accept the current postition as 0. So i changed the code behind the "update z postition" button to: "G90
[[PositionSet 0]]". This is should be the same code as the one behind the homing button. In the Z Axis controll screen i get the right feedback from nano dlp. It sets the current position to 0.
But when i start any print nano dlp allways uses the last known position it got from the homing process.
Has anyone an idea what the problem might be?
Do you receive message "Position set to 0" on dashboard?
Which build you are using?
on the dashboard i get the following messages:
Notice 3 2018-12-02 14:20:58.660775 Terminal Received Data From RAMPS: ok
Notice 3 2018-12-02 14:20:58.656701 Gcode Position set to 0
Debug 3 2018-12-02 14:20:58.656273 Gcode Transfering Data G90
So it´s should be set the way i want it to be. I just tried to recreate the behaviour and it still does the same.
I am currently using: muve3d:1819
I used the newest version before that but since i wasn´t able to customize any buttons in the newer version i sticked to that. Could i maybe uprade to a newer version than 1819 and still be able to customize?
Thank you for your effort Shahin!
Latest beta has custom button functionality
I´ve updated but it didn´t work. I had to put the G92 into the code of the button. Now it works. But by using the beta i get a completely wrong picture displayed.
How it display wrong picture?
