#1 2016-06-08 13:47:44
bolsoncerrado
Add Blackout? What for?
What is this function for? Print a base as big as the printing area as first layer?
#2 2016-06-08 20:57:29
Re: Add Blackout? What for?
It is a feature for users who are printing couple of pieces together. They can disable parts of a plate.
#3 2016-06-09 06:55:44
bolsoncerrado
ah great now I need to use this for a partial failed print plate. is there any documentation on how to use it properly?
#4 2016-06-09 07:08:27
It is easy to use. Just keep left mouse click down it will draw a rectangle. Press add when you were satisfied. Add any number of rectangles and save.
#5 2016-06-09 07:30:50
bolsoncerrado
rectangles=layers you want to keep the blackout?
#6 2016-06-09 07:37:31
Blackout rectangles will be persistent for the all layers. Changing layer at the top merely for navigating and correctly drawing rectangles.
#7 2016-06-09 07:38:00
bolsoncerrado
Gotcha, ty!
#8 2017-05-04 04:24:28
Wisar
I have two objects on my plate, one on one side and one on the other.  I draw blackout over one side of the plate to keep one object from printing.  I do a recreate (is that necessary)?   In any case, both objects are still sliced and showing in layers after the recreate.  I do a dry print and both objects are still being imaged?
#9 2017-05-04 15:45:20
Blackout works in realtime. That means the software will generate them just before using them.
#10 2017-05-04 15:48:53
Wisar
...but the parts were still being projected when I did a dry run?  They were on a damaged part of the LCD so they could have been "less projected" but they were projected.  Just to be sure I will try again once the printer is idle.
#11 2017-05-04 18:06:07
Are you sure you have saved after adding black boxes?
#12 2017-05-04 20:01:43
Wisar
Just validated with a dry run...yes I did a save but the area that I added the black box for was projected (or LCD'ed).
#13 2017-05-05 06:41:40
Please, share debug file. (setup page/ tools tab/ debug button)
#14 2017-05-05 16:44:33
Wisar
WIll do but printer is down now ... :-(
