#1 2018-02-03 08:40:33
78ATI
[[SyscallResult]] in Dynamic Calculation
Hello!
The is a posiblity to pass the [[SyscallResult]] obtained from GCODE before each layer, to Dynamic Cure Time? The same question for Dynamic Speed and Lift.
Thank you for all especialy for this modular software!
#2 2018-02-04 05:29:05
Re: [[SyscallResult]] in Dynamic Calculation
It is not possible to use syscall result on dynamic cure time. But you can use [[ExecReturn]] keyword to execute and place result inside dynamic cure time.
#3 2018-02-04 10:26:48
78ATI
[[ExecReturn]] supports also parameters?  ex: [[python /home/pi/printer/test.py [[LayerNumber]]]]?
#4 2018-02-04 10:54:11
78ATI
I try the [[ExecReturn]] is functioning in the Gcode frame (before and after) but in case of Dynamic Cure time, was no returning any resault. Please can you tell me, maybe is not activate, or i do something wrong!
My .py file have only one row: (as test)
print 21
i try also with: sys.stout.write("21");
On Gcode it's work, but on Dynamic Calculation, (lift,cure) i had no chance!
Thank you for your support!
#5 2018-02-05 01:33:22
You are right. It does not work on dynamic cure time.
Could you let me know what you want to achieve?
#6 2018-02-05 13:41:26
78ATI
Hello! I want to make exposure of current layer based on old layer. In fact i need to store a variable somewhere in the program and to "paste it" in the Dynamic cure time.
For me was perfect if the [[ExecReturn...was working on the Dynamic boxes. Can you help me with this? or can you offer me one alternative to check it?
Thank you for all time and help!
