When the printer is turned on via Wifi, the message “Starting...” is lit on the Nextion screen. If you go through the web to the menu Setup-> Machine Settings, and just save - the Nextion screen is activated.
If the printer is connected via Ethernet, the screen is activated immediately.
please fix screen communication problem
Somik,
I have double checked and nothing related to wifi/ethernet going on HMI code.
Anyway I have changed code a little bit to see if it makes any difference. Will push a new beta version tomorrow.
If the issue still persists, please get debug mode after using ethernet and wifi connections separately, so we could compare the result.
the problem is resolved
The reason was the remaining settings from the Tibius firmware. Started working after deleting the line "dtoverlay = pi3-miniuart-bt" from the /boot/config.txt file
