#1 2017-06-12 04:46:47
danthehuman
Top Down Printer Settings
Hi
I've built a top down printer and started using Nano DLP, I used to use Creation Workshop, but found it limiting.
But one thing I did like was the ability to simply select "bottom up"or "top down" from the setting screen, and then define the lift distance between exposures, speeds and dwell time.
Are you able to add this to your software and or a guide for how to do it, I have thought about inverting the motor direction in the marlin code, but this seems a bit of rough approach to take.
Dan
#2 2017-06-12 07:18:42
Re: Top Down Printer Settings
You could find it below shield options called "Shield Axis Direction"
#3 2017-06-13 01:05:35
danthehuman
Do you have a guide for setting up nanodlp with marlin firmware, for top down printing? I've look through this forum site without much luck, and I cant get my printer to [Print] - [Lower 5mm] - [Return less the layer height] - [Print]
#4 2017-06-13 04:14:11
I know couple of guys on forum using top down systems with nanodlp, but I do not have much information on their settings.
