#1 2016-03-20 20:18:44
Rastati
Z axis Calibration
I am currently triyng to calibrate the Z axis.
In the setup page, I used 500 pulse as height.
If I understand well, the limit switch is placed to the top, so when I use the Calibrate Zero Position Button in the Z axis Calibration page, the motor starts moving slowly until it hits the top limit switch then the current pulse value is set to Zero. Then, if I hit the Floor button, the motor moves to 500 pulse (since its the height). When it gets to the floor and I press the top button, the motor dont switch direction, but keeps lowering.
Am I the only one who have this problem?
Thank you very much!
#2 2016-03-20 20:44:39
Re: Z axis Calibration
Measure button will measure your z-axis length so you do not need to enter manually.
Basic idea is that you move platform down until reach floor level which you are happy. Press measure and it will automatically set z-axis height.
Floor will be the point which you have pressed measure button.
Automatic measurement only works for direct gpio control.
#3 2016-03-20 23:20:12
Rastati
Thanks Sahin, but what i mean is that when I set the height of the Z-Axis and then I press the floor button, then the top button, the direction of the stepper doesent change and it keeps lowering instead of going up.
I am working only on direct GPIO control.
#4 2016-03-20 23:39:08
All of manual move up buttons lowering platform?
Are you sure you have wired direction pin?
Which version you are using?
#5 2016-03-21 01:14:46
Rastati
No, only the top button lowers the platform when Im already at bottom.
I have build 1005, is this the lastest?
#6 2016-03-21 08:13:30
What about down buttons, they go up or do nothing?
It is too old, but it is nothing to do with current bug, I taught maybe a new bug introduced in beta version.
#7 2017-06-20 09:25:24
karthik
In my Nanodlp page, there is no Measure Button in Z axis calibration page. kindly help
#8 2017-06-20 17:28:00
It being displayed for direct control only. For RAMPS you have to add buttons from custom buttons / setup page based on your firmware choice on RAMPS side.
#9 2017-06-20 17:43:44
karthik
I am not familiar with nanodlp
Can you explain with steps please!! I am using built 1209.
Also please explain how to setup, when I hit stop printing it has raise 100 mm
While resume it has to comeback to-100 mm and continue the print
#10 2017-06-20 19:44:35
Watch nanodlp channel on youtube. There are couple of tutorials and walkthrough.
#11 2017-06-21 04:12:10
karthik
Hi Shahin
I watched the videos in Nanodlp Chanel , I can't find the tutorials regarding my doubts
Kindly help
#12 2017-06-21 18:03:03
karthik
Waiting for your information
#13 2017-06-21 18:26:53
Karthik,
If you have specific questions, I believe people here could help you.
#14 2017-06-21 18:47:43
karthik
Thanks , I want to know if i press stop button z axis should go 100 mm up and i press resume it should come back to original position (-100) and continue the printing. What should I have to do
#15 2017-06-21 19:34:12
It depends on your hardware but you could try ready made config files. https://www.nanodlp.com/repo/
Also try read gcode specification, it is very easy to learn.
