#1 2016-04-27 16:08:04
Kuspide
retina display
Hi to all,
i'm new of dlp printer but after one year with my prusa i3 i think that it's time to made a new prokect.
so i wanto to buld m personal sla printer and i want to use raspberry pi and ipad retina display.
so befour staring i have some questione.
1) nanodlp supports retina display resolution?
2) I need to controll only z axis so i need miniaml control ( i think a little arduino with stepper motor driver ) i don'r want to use ramps and mega but arduino uno or nano wit driver. Exist any firmware compatible to made this?
3) the Surface where resin catalize, how it work? i need a specific material? what is the height from the bottom where is the image projected from the retina display?
thx to all
#2 2016-04-28 08:50:56
Xmike
Re: retina display
Have you already seen on this page?
http://www.buildyourownsla.com/forum/vi … =12&t=2113
#3 2016-05-03 13:58:19
Kuspide
Re: retina display
Hi Xmike, thx for you replay.
Yes i have seen that forum, there are more topic about sla with retina display and there are more problem.
one by one i'll try to solve but befour start i need to understand
NanoDLP work with higest resolution? or support only 1920x1080?
How can i connect to sinc z axis? is there a wiki ore a guide?
#4 2018-04-23 05:58:15
JakeTse
Re: retina display
I've learned that the retina display are different on different iPad models. For example, The Retina Display on a 9.7-inch iPad has a resolution of 2048x1536, but the iPad 2's screen resolution is 1024x768. So which level of retina display resolution does Nanodlp support? Go check retina display for each iPad models here: Full List of Apple iPad Models and Generations Till 2018
#5 2018-04-24 18:53:18
Re: retina display
No limitation on resolution on nanodlp side but you have limits on hardware side, for rpi max resolution is 4k
#6 2019-09-28 10:18:32
giantpt
Re: retina display
Hi guys,
This thread interest me... so, keeping the discussion, is the Pi able to output a custom resolution of 2048x1536 to an ipad 3 LCD?
