#1 2017-11-19 16:52:55
Thiengod
Stop print error - Direct control
I use direct control, but when I stop printing, it fails with error "Waiting for done message from RAMPS" and I can not do anything except turn off the RPi3 power.
nanodlp.debug.-1680081502.zip
#2 2017-11-19 17:35:26
Re: Stop print error - Direct control
Remove [[WaitForDoneMessage]] from gcode boxes.
#3 2017-11-20 02:23:15
Thiengod
Hi Shahin
I don't use [[WaitForDoneMessage]] for any gcode boxes.
#4 2017-11-20 07:39:54
I have checkout log files look like you are receiving "Done message from RAMPS has been received" not "Waiting for done message from RAMPS" right? If so, there should not be any movement issue.
#5 2017-11-20 12:57:12
Thiengod
Sorry for the confusion. I received the message "Done message from RAMPS has been received". it doesn't have any movement. I can not do anything after that, even shutdown and reboot. Nanodlp crashes I have to turn off the power
#6 2017-11-21 05:12:10
Could you explain where movement works and where it does not? For example if manual movement works and etc.
#7 2017-11-21 05:22:45
Thiengod
Hi Shahin,
This error sometimes appears, there is no command that can execute. The printer must turn off the power
#8 2017-11-21 05:42:16
With all versions or appeared with recent versions?
#9 2017-11-21 06:48:35
Thiengod
I don't know. I switched to using direct control about 1 month ago. I installed new Pi3 and nanoDLP to be sure no problems with the old settings but still error
#10 2017-11-23 07:04:04
I have tried it locally on my pi. I could not reproduce it. Do you have any RAMPS wired to nanodlp?
#11 2017-11-23 08:43:48
Thiengod
I don't connect RAMPS to nanodlp. Shield Connection is disabled
#12 2018-03-15 03:00:09
Thiengod
Hi Shahin
The error occurs when the stop is pressed while the Z-axis moving down to the print position after pressed "Print From Start"
#13 2018-03-15 05:53:38
It is not important you have shield enabled or not, you still could use keywords such as [[WaitForDoneMessage]] which freeze printer until receive Z_move_done message.
