#26 2016-11-23 17:58:10
Re: Latest build changelog
Build #1282
  • Feature: Dynamic lift value
  • Lots of bugfixes!
#27 2016-12-23 15:38:48
Build #1312
  • Feature: Windows / Linux versions
  • Feature: Recreate Layers
  • Feature: Preview 3D files
  • Feature: Option to change display out
  • Feature: Scale x/y/z resolutions on profile level
  • Feature: Customizable gcode movement buttons
  • Bugfix: Projector Hour Read
  • Bugfix: Initialize wireless connection On-demand
#28 2017-02-14 05:50:48
Build #1352
  • Feature: Manual support placement.
  • Feature: [[LayerSkip Value]] command to skip a layer
  • Feature: [[SkippedLayers]] number of layers has been skipped since the last printer layer
  • Feature: Command line argument support to utilize display automatically.
  • Feature: Custom mask file per plate
  • Feature: New [[PixDiff]] keyword support (Total number of differentiating pixels)
  • Feature: Support more math operations and functions
  • Feature: [[PlateName]] and [[PlateID]] keywords support.
  • Feature: Display layer details on the preview page
  • Change: Gcode is usable for direct control
  • Changes: Improved slicer
  • Feature: Support editing network settings using nanodlp-network.txt
  • Bugfix: Windows / Linux version related issues fixed
#29 2017-02-17 11:28:04
Build #1354
Upgrade go to 1.8. It improves direct pulse generation performance. And the program itself should runs around 30% faster than before.
#30 2017-03-03 08:29:18
Build #1364
  • Feature: Preview support types
  • Change: For desktop version move to pure OpenGL
  • Change: 30% slicer speedup
  • Bugfixes
#31 2017-04-13 22:58:18
Build #1393
  • Feature: Y resolution
  • Feature: Formula Editor on help modals
  • Feature: Import / Export machine settings
  • Feature: Option to modify blur amount on mask generation
  • Feature: Detect faulty PNG files
  • Feature: Plate download option
  • Feature: Support generator new page to arrange plates
  • Feature: Support generator accept multiple files
  • Feature: Display slicer progress on plates page
  • Feature: Plates search
  • Change: Single line to multi line math support
  • Bugfix: Mask generator update issue
  • Bugfix: Display vertical images correctly on dashboard
  • Bugfix: Handle negative fill area calculations correctly
  • Bugfix: Do not process STL files larger than available empty memory
  • +Other small improvements
#32 2017-05-13 18:01:36
Build #1437
  • Feature: Hexagonal Infill
  • Feature: Resize STL models
  • Feature: Display current layer from preview page
  • Feature: Display outdated plates
  • Feature: Display print time for plates
  • Feature: Resin cost estimate
  • Feature: Support toggle buttons on support screen
  • Change: Slicer will work during printing
#33 2017-06-03 20:42:37
Build #1466
  • Feature: RAMPS Reconnect
  • Feature: Display plate form after pressing save plate on support tool
  • Feature: More infill options
  • Feature: Accurate plate print time estimation
  • Change: Use pre-calculated pulse size generator.
#34 2017-06-29 09:43:51
Build #1552
  • Feature: Remote slicer support - RPi NanoDLP sends files to paired Windows or Linux NanoDLP to process.
  • Feature: Auto detect remote slicer
  • Feature: Preview layers page displays Gcode information
  • Feature: Framebuffer support
  • Feature: Custom acceleration
  • Feature: Weave supports
  • Change: Tighter pulse generation for direct control
  • Change: Up to 50% slicer performance improvement
#35 2017-08-07 05:56:20
Build #1589
  • Feature: Hollowing pieces
  • Feature: Enable pin could be toggled between prints
  • Feature: Rotate layer option
  • Feature: List available USB devices on linux
#36 2017-09-04 05:13:50
Build #1634
  • Feature: Full featured Mac version
  • Feature: On-fly barrel distortion correction
  • Feature: Barrel distortion correction preview on projector calibration
  • Feature: Multi language UI support
  • Feature: [[DisplayLayer LayerID]] keyword support. It is possible to display any layer by using gcode box.
  • Feature: [[Blank]] keyword to empty display area.
  • Feature: Min/Max fill area for each layer
  • Feature: Switchable theme support
  • Change: Hollow and hexagonal infill features are twice fast
  • Change: Dashboard improvements
  • Bugfix: Reading from USB does work correctly
#37 2017-10-03 04:26:06
Build #1674
  • Performance: 18% less memory usage for STL slicing
  • Performance: 25% faster STL slicing
  • Feature: Force GC on high memory usage to prevent crashes
  • Feature: Light output formula
  • Feature: Bottom limit switch support for direct control
  • Feature: Mask effect modifier
  • Feature: Comma separated values support for mask generator
  • Change: MaxJewel's Italian translation has been added
  • Change: Update setup script for Raspbian Stretch
  • Change: Disable GPIO on non RPi boards
  • Bugfix: Critical bug on plate add fixed.
#38 2017-10-27 15:05:51
Build #1707
  • Feature: Estimate memory usage and optimize slicing based on available memory
  • Feature: Disable hatching when available memory is not enough
  • Feature: Support color for mask generator
  • Feature: AA for distortion correction
  • Change: Display panic message even on recovery
  • Change: Display time in HH:MM format
Build #1700
  • Performance: It is possible to process STL files larger than available memory
  • Feature: Arrow button to control layer
  • Feature: Get version history on NanoDLP upgrade page
  • Change: Remove PixDiff keyword
#39 2018-02-06 21:20:06
Build #1788
  • Feature: Mirror layers
  • Feature: Add Spanish & Chinese translations
  • Bugfix: Bottom limit reset position to zero
Build #1765
  • Feature: Advanced resin calibration
  • Feature: Additional modes on mask generator page
  • Feature: Support different color for background
  • Bugfix: Fix blackout issue
  • Bugfix: Fix issues on windows display
Build #1745
  • Feature: Custom framebuffer channel support
  • Feature: Display printed pieces height on the dashboard
  • Change: Change working directory to binary address
  • Bugfix: User/Password control
  • Bugfix: Better handling float precision for STL format
Build #1721
  • Feature: Display print statistics on dashboard
  • Feature: Supports 18bit channel framebuffer
  • Feature: Export CSV on mask generator
  • Bugfix: Depth change does not effects number of layers for STL files
#40 2018-02-22 20:48:29
Build #1800
  • Change: Upgrade to Golang 1.10 - around 7% performance improvement including on slicer feature
  • Change: Faster slicing on faulty STL files
  • Feature: Control columns size on calibration plate generator
#41 2018-08-03 21:39:15
Build #1856
  • Feature: Laser based SLS/SLA 3D printer support
  • Feature: Buffer mechanism for Arduino OK responses
  • Feature: Persist page details on all pages
  • Feature: default endstop switch state
  • Feature: Add Russian language translation
  • Feature: Dynamic wait after lift
  • Feature: Add turkish translation (by Onur)
  • Change: Add name of the printer to dashboard
  • Change: Apply math to binary transfer
  • Change: Better memory management on slicer
  • Change: Migrate to systemd from init.d
  • Change: Mark plates as corrupted if during slicing nanodlp process stops
  • Bugfix: Multi stage STL processing does not work
  • Bugfix: Manual support resize issue
  • Bugfix: Fix JS progress bar issue
  • Bugfix: Large pillar height does not work on calibration plate
  • Bugfix: Layer number does not take effect correctly after applying different layer height
  • Bugfix: Dimming does not work correctly with some non-black colors
  • Bugfix: Wireless connection on Stretch
  • Bugfix: Clearing 2K, 4K screens
  • Bugfix: Applying correct mask to the plates
  • Bugfix: Fix pink pixels after distortion correction
  • Bugfix: Reflect thickness of layer on start
#42 2019-03-26 21:15:32
Build #2101
  • Feature: Support Nextion displays internally
  • Feature: Option to disable 3D preview on Raspberry Pi
  • Feature: Enable/Disable auto slicing
  • Feature: New nanodlp format support, it will speedup new plate upload considerably
  • Feature: 3D preview plates
  • Feature: NanoAgent compatibility
  • Feature: Choose limit to reset or not reset position
  • Change: Slicer uses 8% less memory
  • Change: Infill feature uses ~80% less memory, and 10% faster
  • Change: Remove camera raspistill dependency and make camera support generic
  • Change: Compiler upgrade to Go 1.12
  • Change: List all compatible files on /media folder
  • Change: Evaluate math inside gcode keywords
  • Change: Slice from mid of layer instead of bottom
  • Bugfix: 3D preview generator is much more reliable
  • Bugfix: Infill issues has been fixed
  • Bugfix: Solve button condition issues
  • Bugfix: Minor problem on mirroring
  • Bugfix: Custom buttons do not respect printer condition
  • Bugfix: Low quality layer issue fixed
