#1 2017-12-10 17:13:51
PMJ
LayerSkip Value
Updated to the most actual version - now the LayerSkip value is no more cutting away the rest of the gcode in the "Before Each Layer" field.
Warning    3    2017-12-10 16:49:20.778185    Printing    Layer has been skipped
Notice    3    2017-12-10 16:49:19.977706    Terminal    Received Data From RAMPS: wait
Notice    3    2017-12-10 16:49:13.978633    Terminal    Received Data From RAMPS: ok
Debug    3    2017-12-10 16:49:13.977681    Gcode    Delay Printing For 6.8 Seconds
Debug    3    2017-12-10 16:49:13.977289    Gcode    Transfering Data
M201 Z 15.0000
G1 Z 10.0000
G1 Z-9.8500
Warning    3    2017-12-10 16:49:13.977248    Gcode    Layer set to be skipped
It seems, that the layer ist set to be skipped, but first the remaining Gcode will be executed before the Layer at the end of this gets skipped...
#2 2017-12-11 07:11:21
Re: LayerSkip Value
It should skip layer itself not gcode. The issue is that if we skip remaining gcode, any movement and etc will be skipped too.
I do not thinks people currently using this feature so if couple of users agree on how it should be behave we can change it.
#3 2017-12-12 04:42:33
PMJ
Re: LayerSkip Value
thanks for your reply & no problem. I just have seen, that in older versions also the gcode has been cut away. Now I changed the strategy a little bit and the gcode stuff will be executed in the "after the layer" part and all is working fine again.
