#1 2017-07-15 23:35:19
danthehuman
Wiper control
Can a wiper control be added, so after the dip and retract sequence (Top Down Printing), a wiper on the X Axis runs across the resin surface (number of steps field), with the added option of one way or a return trip tick box?
#2 2017-07-16 05:25:17
Re: Wiper control
If you are using RAMPS you can already have it.
#3 2017-07-16 05:44:22
danthehuman
Re: Wiper control
I'm using a ramps 1.4 and Marlin firmware, how would I implement the wiper on the x axis to run after the lift sequence before the next exposure?
#4 2017-07-16 05:50:12
Re: Wiper control
At the bottom of after layer gcode box, you can add new gcode for other movements for example G1 X20, but you need to use [[WaitForDoneMessage]] to synchronize all movements.
#5 2017-07-16 05:59:48
danthehuman
Re: Wiper control
Ok i'll have a play round with it, and see how it goes. But first I have to solve the top down lift sequence for my top down sequence with out reversing the Z axis wiring
