#51 2017-11-01 04:14:37
Yianni-VJ
Re: Touch screen for NanoDLP
My Nextion was connected and talking to the Pi but now it's not.
The only thing changed was unplugging the Logitech USB keyboard receiver.
I upgraded to the newer version but it did not change anything.
The output.log in Nextion folder says:
error opening port  /dev/ttyAMA0 retry in 2 seconds
The cmdline.txt reads as follows:
dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=20bc60e1-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Any clues guys?
#52 2017-11-01 09:36:45
mickymax75
I run rhe simply installation...i suppose it replace the older version
#53 2017-11-02 20:51:05
mickymax75
Hi Julien I installed v2.0 and lcd after 30s turn it off...but when I start a printing from pc....lcd does'n t move....is still on the first screenshot
#54 2017-11-03 15:25:28
mickymax75
if I click on plates button...all plates are "UNDEFINED" any help????
#55 2017-11-03 19:26:12
juliendelnatte
Will Check it this weekend. Could you tell me your nanodlp version?
#56 2017-11-03 19:37:30
mickymax75
Upgraded at the lasy syable version.thanks a lot
#57 2017-11-06 11:27:10
mickymax75
Hi Julien
This week I reinstalled all nanodlp image with the v2.0 of your sw.
Now it seams to work but when printing on nextion lcd I dont have the preview images of processing layer.
I mean the black rectangle on the left side
#58 2017-11-07 13:13:18
mickymax75
Hi Julien...any news???? big_smile
#59 2017-11-07 13:36:38
juliendelnatte
I'm working on it, there was some update on nanodlp that change the screen behavior, so I'm fixing this. there will be a V0.3 in few days!
#60 2017-11-07 14:57:02
mickymax75
Ok
But we can use the v2.0...or is better use the v1.0?
#61 2017-11-07 15:32:14
juliendelnatte
V2.0 works but there is some bug. you can use it but maybe use V1.0 for now is better
#62 2017-11-07 15:42:35
mickymax75
Ok...the beat way for downgrade veraion is simply delete folder and reinstall v1.0?
#63 2017-11-07 15:43:33
juliendelnatte
yes, but if you can wait 2hours, I will update the V2.0 on the github to remove bugs!
#64 2017-11-07 15:44:12
mickymax75
Yes....perfect
#65 2017-11-14 13:09:44
mickymax75
Hi julien
May I download the newer version?
#66 2017-11-14 13:55:38
sgraber
Would someone more knowledgeable care to look at my mods to the nextion 2.4" touchscreen?
https://github.com/sgraber/TouchScreen-For-NanoDLP
Based on what I can tell, I have modified it appropriately, but none of the 4 buttons I placed in the home.js file work.  They show up on the Nextion screen and I can press them, but they don't call the proper URLs, which are /button/press/0 and /button/press/1.  Thank you!!!
#67 2017-11-14 14:02:10
juliendelnatte
Hello, it's not the name software listen to but the id of the button. So you have to change
this.addListener("click_c0", () => this.nanoDLP.command("/button/press/0"));
this.addListener("click_c1", () => this.nanoDLP.command("/button/press/1"));
this.addListener("click_c2", () => this.nanoDLP.command("/printer/off"));
this.addListener("click_c3", () => this.nanoDLP.command("printer/restart"));
To
this.addListener("click_b4", () => this.nanoDLP.command("/button/press/0"));
this.addListener("click_b5", () => this.nanoDLP.command("/button/press/1"));
this.addListener("click_b6", () => this.nanoDLP.command("/printer/off"));
this.addListener("click_b7", () => this.nanoDLP.command("/printer/restart"));
#68 2017-11-14 14:29:15
sgraber
juliendelnatte:
Take a look at "2.4_LittleRP.HMI", which is the one I modified for my LittleRP resin printer.  If you look at home.js, you will see four new buttons with objnames c0, c1, c2, and c3.
I then reference them as I did in the following two files:
https://github.com/sgraber/TouchScreen- … es/home.js
The /button/press/0 event calls an M8 gcode which disables my stepper.  The /button/press/1 event calls M9 gcode which enables the stepper.  Pressing either of those buttons do nothing to my stepper motor at all.  If I log into http://localhost/ I can click the button on the webpage that calls these two urls and they work.
I'm at a loss why it's not working.
#69 2017-11-14 14:34:21
juliendelnatte
It's what I said, I looked at your HMI and your code. It's not the name of the component is sent to the program but the ID. and the event is "click_b"+id. So I sent you the fix
#70 2017-11-14 15:08:30
sgraber
Oh my goodness.  Is that it?  It uses the id instead of objname?   /me smacks his head
#71 2017-11-14 15:09:09
juliendelnatte
Yep, the code I give you should work.
#72 2017-11-14 15:23:23
sgraber
Thank you so much!!!
#73 2017-11-14 15:30:50
Doug
Is the add from Usb working now?
#74 2017-11-14 15:31:48
juliendelnatte
Not yet, have a lot to do on my printer and not done the usb and new UX yet
#75 2017-11-17 12:31:37
rob
I'm stuck with the same problem on a RPi2B and a Nextion Basic 3.5". I'm running v2. I think I tried all solution I saw online, but I can't find the issue.
I initially thought it was a permission/serial port issue, but after some checking I just realized  it's should not.
/home/pi/nextion/output.log:
{ nextion: { port: '/dev/ttyAMA0', sleep: 30 },
  pushbullet: { apiKey: null } } { apiKey: null }
connect to port /dev/ttyAMA0
list [ { comName: '/dev/ttyAMA0',
    manufacturer: undefined,
    serialNumber: undefined,
    pnpId: undefined,
    vendorId: undefined,
    productId: undefined } ]
connected
On startup I have a root process running "node /home/pi/nextion/bin/index.js". Not sure if it should be root. I tested as user pi running the same process from command line and got the same output [connected].
Any hints? Is there any command I can try to send through minicom to completely exclude any  communication-related problem? Like the command display is expecting to move to the main screen.
