#1 2016-09-04 20:59:25
Kvirre
Mirror Projected image
In a print I made I noticed that my letters where mirrored.
And I would like to flip my XY axis on the projector, how do I do that?
#2 2016-09-04 21:15:15
Re: Mirror Projected image
Check out your projector's manual.
#3 2016-09-05 06:28:37
Kvirre
It's not really a projector (I only wrote that to use the same terminology NanoDLP uses).
I use a iPad-LCD driven through a displaydriver (not possible to do any settings).
I was looking for something found in Creation Workshop .... Flip X and Flip Y in the "Setup" section.
#4 2016-09-05 06:37:36
It takes some processing effort on rpi. I will try to add it without major performance hit. It is probably the worst place to handle the issue.
You can try flip function of your 3d design program before I could add it to nanodlp.
#5 2016-09-05 06:58:36
Kvirre
Ok, I see.
I might have found a solution ... in rpi : config.txt one could apparently add : display_rotate=0x10000
This should flip in X and to filp Y (mirror) one could use  : display_rotate=0x20000
Makes me think that I could flip both using : display_rotate=0x30000
Will try it later today.
This would hopefully not strain the processor of the RPI
#6 2016-09-05 07:09:40
Good find, I doubt it will have any effect on rpi processor.
#7 2017-02-04 00:11:34
jamesarm97
Fixes the mirrored text and all the webpage images but the slicer seems to ignore the resolution and slices portrait mode.
#8 2017-02-04 07:32:14
As long as you entered correct width and height on the setup page it should work. Slicer will initialize based on the setup value.
#9 2017-03-05 18:39:30
Gatto
On win and lcd, no way to have mirrored images ?
#10 2017-03-05 20:04:52
UltraMon could do that on windows. You can mirror your pieces with your design program. It is something could be added to nanodlp but it have negative effect on performance.
#11 2017-03-06 08:47:59
Gatto
I know on PI working with rasters negatively affects cpu performances, but on x86 mirroring, also from a shell, is very fast.
I can give a try using syscall to see what happens, if you implement something like [[CurrentRasterFileName]] or similar, otherway with only layer n is quite difficult to locate raster to process.
This can also open to raster compensation, if needed.
#12 2017-03-07 03:19:12
There are couple of ways to do that.
1. You can run separate service to watch plates/ folder for new files and process them.
2. On gcode box before layer use [[ExecReturn run.bat plates\[[PlateID]]\[[LayerNumber]].png]] (I am not sure how it will works on windows.)
3. On gcode box start [[Exec run.bat plates/[[PlateID]]]], watch folder for new file and rotate any new file.
#13 2017-03-07 08:40:32
Gatto
Nice tip, I'll give a try, thanx
