#1 2018-02-23 10:35:02
bman
Soft limits
Is there a way to change the 185mm z height limit?  I wouldn't to set it to 200mm.  Do I have to take the SD card out if my pi and fiddle with the config file to change it?
#2 2018-02-23 10:50:05
Re: Soft limits
On nanodlp side there is no limit on z height movement except end-switch limit. If you are using RAMPS, try change limits on the firmware side.
