#1 2016-08-19 18:36:34
Kvirre
Max resolution?
I'm using a custom resolution of 2048x1536, but under "projector calibration", all modes seems to display 1080p regardless of my configuration under Setup>Projector?
#2 2016-08-19 19:16:19
Re: Max resolution?
Resolution 4K and under is fine with nanodlp as long as you can correctly choose HDMI mode. Projector calibration page fixed on fullhd resolution as all of the resources are static, I am going to make render engine to render grids in realtime to fix the issue in the future.
#3 2016-08-19 19:48:41
Kvirre
Re: Max resolution?
Ok, then it's not really a problem.
I have not got around to fully configure and try to display slices (that should work if I understand you correctly).
The hdmi-mode should be configure properly in config.txt, now I just need to try it out
Thanks for the swift answer.
