#1 2017-11-16 13:13:50
MaxJewels
Z axis page
Can I hide the Z axis calibration page?
#2 2017-11-16 15:07:09
Re: Z axis page
Add css rule to style.css or remove it from html file.
#3 2017-11-16 17:07:31
MaxJewels
Re: Z axis page
Thanks a lot .. I thought it was much more complicated ... I deleted the voice from the menu.html file
#4 2017-11-21 10:20:50
riguardino
Re: Z axis page
sorry guys,
where is located menu.html or style.css?
I can't find in the nanodlp microSD card
thanks a lot
#5 2017-11-22 06:01:52
Re: Z axis page
/home/pi/printer/public/css/
/home/pi/printer/templates/
#6 2017-11-24 12:58:26
riguardino
Re: Z axis page
there aren't this folders in my microSD. maybe it's all wrong in my mind :-(
#7 2017-11-24 13:35:54
rob
Re: Z axis page
You have two partition in the SD:
  1. Boot partition, FAT32
  2. Linux partition (Ext3 or ext4, I guess)
Main filesystem is on n.2, while you are probably looking at n. 1. You will need to access it from a linux system or install a windows driver. Otherwise, if you enable it, you can just SSH into your device and make changes from command line or remotely connect through SFTP and explore folders.
