#1 2016-10-19 08:54:26
caripen
How can I fix my IP adress?
I'm using raspberry Pi with nanoDlp and I have to search every time I turn on the raspberry Pi wich IP adress is working on.
How I can do it to fix this IP?
Thank you.
#2 2016-10-19 18:35:43
Xmike
Re: How can I fix my IP adress?
I have in the router indicated that it always gives the Rpi the same IP address via dhcp
#3 2016-11-22 12:15:39
caripen
I sitill does not know how to fix my IP.
Can you explain me a litlle more about this process to fix the IP?
Thank you
#4 2016-11-22 20:22:03
As Mike mentioned you can change DHCP/NAT settings on your modem to reserve IP for your rpi. But it depends on your router type.
Another way is to edit /etc/network/interfaces file and make rpi IP static. There is numerous guide on how IP should be made static on linux terminal.
#5 2016-11-24 10:06:21
caripen
I want to do it on linux terminal, but how I can connect to the rpi terminal where I have nanodlp installed?
#6 2016-11-24 16:18:29
If you are windows user, try putty to connect to raspberry pi.
#7 2016-12-09 11:21:57
caripen
Hi Shahin,
I am still trying to fix my IP.
I have my Raspberry PI with nanodlp installed. What I have to connect and where to be able to connect to the terminal of my raspberry pi ? Because when I connect my raspberry pi to a LCD Display I can see anything at all.
Thank you so much,
#8 2016-12-09 21:18:33
The display connected to raspberry will be used for layer projection so you could not use it anymore.
Use tutorial below to connect to RPi
http://www.hobbytronics.co.uk/raspberry-pi-ssh
#9 2016-12-13 11:03:30
caripen
Thank you so much Shahin!!
All clear now
