I have a problem with the setting of my screen (lcd screen 7" 1024*600 154.08mm*85.92mm),
in horizontal resolution I put "1024", in vertical resolution I put "600" and "150" in x/y resolution, but when I test (without resin) by printing a square object it appears rectangular and different size ...
Please answer
cordially
Use boundary display on projector calibration page, maybe overscan causing the issue.
thank's for your reply, I can't find the coresponding parameter, could you tell me where is it ?
cordialy
You can change overscan related settings on config.txt file.
I changed the value of the overscan, I put 20 instead of 16 for the left and right but nothing to change, I always see a rectangle ...
Make sure you have not disabled it through config.txt
I removed the "#" before the command
