#1 2017-06-12 03:04:24
Pyper
Z axis moves under calibration, but not during print
My Z axis stepper motor moves correctly under the calibration tab, but does not move at all when printing.
Could this be a resin profile problem?
#2 2017-06-12 07:12:24
Re: Z axis moves under calibration, but not during print
If you are using RAMPS, yes it is gcode issue.
#3 2017-06-13 13:40:19
Pyper
I cannot get the z axis stepper motor to change speed.
It only moves at a very slow rate.
Even if I use a direct g code in the terminal, like:
G1 Z-250 F700
It just creeps along barely moving and should go much faster
#4 2017-06-13 16:24:45
Pyper,
If you are using RAMPS, you need to check firmware settings on RAMPS side.
