An I correct that this feature (burnin-erode) is supported in the Rpi version but if using a remote slicer it will be ignored?
Could not get it to work at first, but then suddenly it started I then realized my remote slicer went offline....(remote is linux ver 2177)
Make sure both versions are same.
I can't seem to get a newer Linux system (desktop remote slicer) than 2177 using: wget -P ~/Desktop/ "https://www.nanodlp.com/download/nanodlp.linux64.zip"
Is there a different way to get the Beta?
It does show in blue on the dashboard that there is a newer version available but since there is no internal updater
in linux using wget is all I know how to do.
Positive value makes object smaller and negative - bigger?
correct...I use -0.3 to reduce elephant foot issue on burn in layers of models printed directly on the platform
If you use -0.3 (negative) for reducing - I`m wrong
