#1 2018-04-18 03:22:24
Yianni-VJ
Restart button does not always restart Rasbian
I have set up my printer to run unattended.
I want to restart the system after slicing to make certain I don't have memory issues during print.
Problem is that restart command works 50%-60% of the time. Is it just me?
Is there a way to make sure the system will restart when I issue the command through nanoDLP?
#2 2018-04-18 07:22:25
elshad66
Re: Restart button does not always restart Rasbian
do not need to restart
if you restart and wait a long time
poor nutrition
put any
https://www.ebay.com/itm/DC-DC-10-12-15 … gjzgH2AcDQ
https://www.ebay.com/itm/5A-Adjustable- … SwUn9aTafX
and install 5.2 volts for power pi
#3 2018-04-19 20:26:59
If you are not using PWM, disabl pigpio binary, it is the causing this issue.
#4 2018-04-20 23:23:25
Yianni-VJ
Hi Shahin,
I googled "disable pi gpio binary" but I can't find instructions on how to do it...
Can you please help?
#5 2018-04-21 13:36:08
adam
#6 2018-04-23 20:55:22
Yianni-VJ
Thank you very much Shahin & Adam !
I issued the command:
sudo systemctl disable pigpiod
Restart always responds and memory usage appears to be lower.
Makes me want to try using the camera again, to see if it I can avoid crashes.
