#1 2019-07-19 19:14:07
macdarren
minor GUI add...hide buttons....
This is pretty minor but...
I'd like to see a way to hide non functional or irrelevant buttons.
For instance:
Resume buttons should not show unless there is really something to resume from.  A just completed plate can't resume.  A plate that was not the last one printed can't resume...at least given the current tech.
Also the printer set could contain a printer 'type' this would allow for hiding features not relevant to that machine type or maybe relabel items to better match the printer in use.. making things less confusing maybe...this might be harder and of questionable value....an example is shutter for an lcd printer is not really a thing.  Maybe it means uv source off, maybe it means all black lcd?
Just a couple thoughts.
#2 2019-07-20 18:44:03
Re: minor GUI add...hide buttons....
About resume button, it should work as you described. Please, let me know if it is working in a different way.
Would love to find a solution to decrease clutter without adding new options.
#3 2019-07-25 00:29:14
macdarren
so here is an example of the resume buttons always being visible even though it probably should not be....
https://www.dropbox.com/s/m9gw6e62se0ns … 9.jpg?dl=0
note also how some of the white boxes say 'Laye"
I am guessing it should maybe just be a '0' ... maybe it says "Layer 0" but I can't see that on my screen...it has always been this way.
#4 2019-07-25 01:30:49
Ok, you mean plates list page. When you put layer number and press resume, it will start from the typed layer but start print will start from layer 1 no matter what typed on layer box.
Maybe it is better to have one button.
About Laye, it is due to insufficient space.
#5 2019-07-25 02:00:12
Removed extra button, add more space to solve Laye issue.
